Brian
I've always raised CB on downwind to reduce drag when I'm looking for max speed, but kept it full down upwind, thinking this max's the ballast/righting moment, min's the sideways motion thus helps optimize point as well as speed. The Jobson fundamentals book I have has an interesting small boat technique for upwind in heavy weather that I've been wondering about since i got the 240. My interpretation of this is that the CB essentially counters the sideways motion and that this basic resistance factor plays a huge part in how much your boat heels over. He suggests cranking it up a few inches thus reducing the CB area will reduce the heeling and hence the weather helm (keep in mind that he is probably referring to the type of smallboat CB that raises straight up and down and not a swing type CB. I assume the cost of doing this is you will lose more ground to leeward. But, since you can't really reduce 'area' in the same manner with a swing type CB, plus you affect the righting moment, I've always shrugged this off as impractical for my boat's CB - BUT, i've never tested it just to see what happens! Any thoughts? Anybody nuts enuf to try this yet? I'm real curious...Could use a little guidance on your CB trim techniques in general - when do you all play with the CB?Thanks! Brian
