Portable Buddy Works Great!
Jim,Got to my boat (H34) this past weekend and the temperature inside the cabin was 30 degrees. So I closed off the v-birth, head, and quarter birth by shutting the doors to each. Fired up the Portable Buddy and set it on high (9000 BTU). In a little over an hour it was very comfortable. In two hours it was was just under 70 degrees in the cabin. This is my second winter using the unit and I like it very much. As you know you can hook it up directly to a 20lb tank (keep it outside of the cabin) using the adapter that is sold as an accessory. I'm still using the 1lb throw away canisters but will make the change to the larger tank this winter.It's simple, inexpensive, and it works.Good luck,Joe
