Best Spray Odor Neutralizer?
11,766
I remember Peggy recommending an odor eliminator spray that supposedly worked really, really well. I'd like to sray all those hard to reach areas of the boat that can get stinky but want something that really works and does not just mask odors. I thought it was called Pure Air/Aire/Ayre or something like that but I now see she's recommending K.O. is K.O the best stuff to use???
May 31, 2007
784
Hunter 37 cutter Blind River
Malodour
I have friends who swear by plain simple old hydrogen peroxide. Put it in a squirter and go to it. Try not to get it on your upholstery.
Mar 3, 2008
2
Catalina 28 MKII Keyesport
Atmosklear
Atmosklear is the best stuff I've used. We even used it on our dog when she had an encounter with a skunk. check it out @ http://www.maryellenproducts.com/atmosklear Jim
Dec 2, 1997
9,011
- - LIttle Rock
Pure Ayre or K.O...both are good
K.O. will eliminate any residual organically caused odor. PureAyre will too, but unlike K.O. will also eliminate residual diesel, smoke and other non-organic odors. Both are safe for use on both hard surfaces and soft (cushions, PFDs, musty foulies etc). Note that i said "residual" odors. Neither product is a substitute for a thorough cleaning to remove the source of the odor(s). Neither will "neutralize" odors...neither is a bilge cleaner, or something you can just dump into the bilge to mix with the primordial soup...you MUST CLEAN first get rid of the source of the odor before using either one--or any other product. If you don't the odor will just come back. When treating cushions, it's important to use enough to penetrate all the way into the middle of the cushion from both sides...just spraying the surface accomplishes little...the odor will come back.
Feb 11, 2006
141
Hunter 34 Galveston,Texas
high grade bacteria
there is a product called betazyme from beta technologies here in houston.this product has seven types of high grade long life bacteria that produce billions of enzymes which eliminate malodors and degrade grease,soils,fats oils,mold ,mildew,smoke.urine and on and on...and safe for the enviroment...its smells pleasant.there is nothing you can't spray this stuff on.it comes in qt. bottles and you put a sprayer on it and go to town.i have tried everything on the market and this is the best.it really breaks down diesel if you get it in the bilge.i keep a constant supply on board.it works excellent on and around the head...phone # is 800-647-9700. not sure about website...
Dave Groshong
SBO Staff
Staff member
Jan 25, 2007
1,867
Catalina 22 Seattle
Pure Ayre here..........
http://shop.sailboatowners.com/detail.htm?fno=400&group=590
