I've got a Yanmar SB12 in my Catalina 30 and running the engine is a headache if you want to go below. The sound will drive you crazy. I even have to put the companion boards in place while in the cockpit. What the best insulation to use? The engine cover was modified to accomodate the taller engine(I believe she came with an Atomic 4 gasoline engine)! It will have to be thin on top! Any and all suggestions would be appreciated.
