Best size outboard for a H23
13
hunter 23 lake wallenpaupack
Hi all, I have a 8 hp 2 stroke on my H23. I'm thinking of going with a smaller 4 stroke(maybe 5 or 6 hp). I'm on an inland lake that is approximately 14 miles long. Does anyone know a good size to go with without sacrificing too much speed or power? ...........thanks for your advice, Mark
Kermit
Jul 31, 2010
5,721
I use a 6 HP. Don't know if bigger would be better but I'm happy with what I have. The only time I've wished I had more power has been in pop up blow hards.
Mar 27, 2010
84
Hunter 240 Branched Oak Lake, NE
I have a 6hp on my 240 which I sail inland as well. I agree - the only time I had wished for a little more hp when heading straight into some of our great plains gusts. Otherwise it moves the boat well. Others in my marina with similar boats seem to have either 6 or 8.
Jul 26, 2010
140
Hunter 23 South Haven, MI
I had a 5HP on mine for a couple years and it worked great up to about 4-5 ft waves. Beyond that and it was underpowered. I upgraded to an 8HP for Lake Michigan, but for a small inland lake, 5HP is more than sufficient.
Jan 31, 2013
23
I sail a similar sized lake and have a 20 year old 5hp two stroke strapped to a 23.5. It runs like a champ and works great getting in and out of a marina overrun with 70mph bass boats.
-na -NA Anywhere USA
For the 23, the smallest engine I would recommend is the 5 hp and max is the 8 hp. Most 8 hp are the same engine as the 6 but higher rpm but I have been out of the buisness for a while and I may be wrong. Anything over the 8, then you have to deal with the outboard motor bracket and beefing up the transom to hold that engine but you will be overpowered anyway.
Dougo
Nov 22, 2010
82
Hunter 23 Great Sacandaga Lake, NY
I run a Honda 5 hp, 4 stroke. Works well, but you really need to anticipate stops since reverse is a bit weak when you're moving forward. Overall though, it works fine.
