Hate to tell you....
Tom:I hate to tell you but asking a question like this what is the best (fill in the blank)CarBoatPlace to livePlace to sailPlace to eatSail Manufacturerwe can go on and on. This is a loaded question. Doyle is a very good sail maker as Justin mentioned. I think, like anything else, you need to look at their work and see if they understand your boat and the sailing environment. Hopefully you can get some references from other sailors that have used their products and go for it. It you are getting quotes from several sailmakers make sure that you are getting the same material with the same extras (reef points, batten types, leach lines, material weight, slug type, etc etc).
