Best propeller for a Beta 14?
Sep 30, 2013
3,620
All you guys with Beta engines ... what prop are you using? Thanks!
Jul 31, 2012
38
The propeller system we bought for the Beta 14 for my Vega is Danish, a two bladedFlexofold; item number 1308r 13x8 R bladeset in a 1” SAE 2 blade hub.  Beautifully machined, has worked flawlessly in an area where lobster fishing bouys & lines abound.Price in 2012 was $1020, plus $40 shipping.  Pricey but having tangled with lobster bouys here in Maine all my life, it is a relief to have had no more problems along that line, ie, when sailing the blades fold to a streamlined shape, much less drag...Their web site is @...from my pad nn
May 30, 2006
1,075
Max Prop
You can adjust the pitch until it perfectly matches the engine.
If you change engines, you dont need to buy another prop.
Dec 14, 2013
50
Albin Marin Vega 27 Venice
I have installed the Beta 14 with Technodrive 40 transmission with reduction 2:1 (it is essential to have this information together with engine and boat characteristics to define the prop size). As propeller I have purchased:-A Max-Prop feathering propeller with diameter 33 cm and about 20° pitch (which can easily be modified). This corresponds to about 13x9". Size suggested by the Max-Prop specialists.-A spare 3 blades fixed 12x9" as suggested by the Beta dealer:)
