Dave Zeryck
I'm new to a Cat27 ('76) with a holding tank installed. Was testing the loo this weekend after reading all the HM archives.The head needs lube, which I'll do. It'll pull water in OK, but won't pump into the holding tank. Tested with just water, it will pump out the thru-hull if the Y-valve is in that position.With y-valve going towards tank (bladder type), won't pump out, I feel backpressure.Since the bladder does not seem to 'inflate', I assume there is blockage between the y-valve
