New Orleans / Mandeville
The Mandeville area on Lake Ponchatrain has several marinas that allow live aboard. The rates vary depending on the size of your boat, of course, but should run in the $250 - $350 per month range. The sailing on Lake Ponchatrain is good with fairly easy access to the Gulf for extended cruises.Mandeville (on the north shore of Lake Ponchatrain) is a quiet, small town atmosphere with several areas of historical significance. It has scenic bike trails, hiking, fishing. The climate is the same as you have in Pass Christian. It's where I plan to settle. Good luck.
