So you like Tohatsu... How long have you had it?I bought my Tohatsu from onlineoutboards called and asked all kinds of questions. they were very friendly and it works great
These guys seem to keep a fair marketshare. Everything's a crapshoot.
http://www.onlineoutboards.com
And I tried so hard to craft my question carefully to avoid thisI don't see a problem with a few extra inches of penetration.
Yep no Honda's but we bought two Tohatsu's from them (9.8 HP extra long shaft, 25" and a long shaft 3 1/2 HP) and were happy with the service and so far the motors both worked great. I just serviced them both with new impellers before heading to Florida and when I went to start the 9.8 after it had set for 3-4 years I hit the button and it started within a second. The 3 1/2 is pull start and didn't have any problems with it either.
I'm sure the Honda is a great motor also. I was a Honda/Suzuki motorcycle dealer in the late 60's and then preferred the Suzuki's over the Honda's but that was a long time ago :cry:,
Sumner
[FONT=Arial, sans-serif]============================
Our Endeavour 37
Our MacGregor 26-S Pages
Mac-Venture Links[/FONT]
I started it at home in a barrel before coming down here.Its not the length that matters but how... (ok..never mind_)....Sumner, did you get the Mac in water yet? Sounds like you did if you started it.. .
Yes Tohatsu makes them along with the Mercs under I think 15 HP and also Evinrude (Bombardier) small motors......Is Tohatsu and Nissan really the same motors?
So I guess if you go this route it comes down to how much more will you pay for a different name on the outboard?Evinrude outboards produce two-stroke direct-injected engines ranging from 25 hp (19 kW) to a 3.4L V6 300 hp. They used carburetors until the late 1990s, when FICHT, a fuel-injection technology, was introduced. However, FICHT proved to be an unreliable system, and they soon switched over to a more modern high pressure direct injection system combined with an engine control unit (ECU). They have branded this system as "E-TEC". They also provide four stroke outboards produced by Tohatsu, in the range of 3.5 to 15 HP. These are the same engines that Tohatsu provide for Mercury Marine. ( http://en.wikipedia.org/wiki/Evinrude_Outboard_Motors)
I wouldn't worry about that myself. I think the Tohatsu is 90+ and the way I have mine a little aft of the transom itself that creates a lever arm and it might actually be more weight considering that vs. the Honda.I can't seem to find any weight limit information for the motor transom mount on the 26S. Do you think 107lbs is too heavy?
The Honda generates 12-Amp (148 watt), which sounds great, but it weighs 107lbs.
I've only used it a few times so far and it's worked great . Also look at price difference between Honda and Tohatsu there's a lot of dinners out to smooze the wife when you spend $ on other things for your boat cause it's a disease that once you catch it it's almost incurable. Good luckSo you like Tohatsu... How long have you had it?
