Best 'O" ring lube?
Dec 25, 2014
84
Catalina 27 Pasadena, Md
I work on medical equipment .including anesthesia equipment, that uses "O" rings, and a product called krylon is the best choice due to oxygen flashing causing fire, but not sure I need that for regular maintenance on sailboat parts, what do you recommend for a good all around "O" ring and rubber lube? I am rebuilding my head soon, but also have other rubber items I would like to use it on a as well.
Mar 20, 2012
3,983
silicone grease... NAPA part# 765-1351
its the same as dielectric grease, and what is recommended for o-rings... although there are several manufactures, napa is the most readily accessable...
for an oxygen rich environment, I believe the product you speak of is Krytox, which is more of a teflon lubricant. much more expensive.
15,184
I believe that Super Lube synthetic grease is recommended for head maintenance.
JamesG161
Feb 14, 2014
7,744
Hunter 430 Waveland, MS
If your O-Ring is for a compression type seal....
NOTHING!
Most use simple Vaseline to help hold the ring in the grove while compressing the seal surfaces.
Since O-Rings are made from various elastomers, careful if you select a Lube not compatible with the rubber.
Jim...
Mar 20, 2012
3,983
yes, thats excellent grease also.. a combination of silicone and teflon.... its not considered dielectric due to the teflon and other minimal additives, but it is waterproof and will work great in the application.... but probably harder to find locally.
Mar 20, 2012
3,983
NOTHING!
Jim...
this is exactly why silicone is best for the purpose of lubing o-rings... its inert and the highest temperture grease available on the open market... but it is NOT an EP grease, so in bearings and such, its not the best choice, unless its in an underwater application where a non waterproof grease could wash out.
in some application, the o-rings must be lubricated or they will wear out too quickly due to the friction.... sometimes the device cannot even be assembled without lube on the seal.... so sometimes you could be right about not using lube, and sometimes not... it just depends on the application;)
Oct 24, 2010
2,405
Hunter 30 Everett, WA
CAREFUL THERE
Some O ring material is not compatible with silicone. It can cause it to swell. What you use id dependent on the O ring material and the surfaces in which the O ring is mounted. As a general rule: if it's a seal for petroleum products you should be able to use petroleum such as grease or Vaseline. If it's for water, or salt water, silicone may be better (but I don't know for sure.) This I do know: some materials aren't compatible with silicone and some aren't compatible with petroleum.
Ken
capta
Jun 4, 2009
4,905
The best lubricant for rubber is fresh water.
Dec 25, 2014
84
Thanks all, and yes, centerline, krytox is what I was trying remember the name of. Thanks for all the info.
Bob
Mar 20, 2012
3,983
CAREFUL THERE
I believe you are wrong.... using the wrong type of fluids or lubes with certain o-rings can cause problems, but when this is an issue, they use a silicone based fluid, and silicone based fluids have a much higher operating temperature and are a lot more expensive.
silicone will work as a lube on all orings... even silicone orings.
Oct 24, 2010
2,405
I used to think as you do. In 2009 Boeing had a problem with sticking autopilot disconnect switches. It took considerable effort to identify the problem. These are simple switches that are mounted in the control wheel. It turned out that the flightline guys had lubed the switches with silicone based (Dow Corning DC4) grease and it caused the parts to swell which inhibited movement. The swelling took some time so the problem wasn't seen until the airplanes entered service for a week or two. This wasn't a safety problem (because the switches would only prevent the autopilot from engaging) but a warranty issue never the less. To date autopilot switches are left dry for that reason. Sorry but I don't remember the exact formulas involved.
Back to boat O rings. Use manufacturer's recommendations or risk early failure. This isn't theory and I'm not guessing, it's based on experience and a detailed materials analysis. I'm a 4 years retired Boeing Flight Analyst.
Ken
Mar 20, 2012
3,983
Ken
after doing some research on the Dow Corning Compound4 , which is a silicone based product, it does have a warning that using it in certain applications can cause seizing....
the DC4 product is not as commonly used by the general public as is the 111, which does NOT carry the warning, and which is recommended by ALL manufactures of SCUBA equipment as the lubricant that should be used when servicing SCUBA components...
Parker-Hannifin, who is a supplier of products to the aerospace industry, only offer two different lubes for seal and o-rings, a lithium based product and a silicone based product... their claim is that silicone can be used on all seals and o-rings, yet in some high volume applications it may be cheaper to use a lithium based grease.
so we have to conclude there may be some special seals used in the aeronautics industry are sensitive to silicone lube, OR... that they are sensitive to the thickening agent that is used in certain silicone compounds. but not at all common in general use.
so you are correct.... not all seals are always compatible.
but hopefully we can agree that we shouldnt be comparing an airplane with a toilet, when deciding what to lube the crapper with:biggrin::biggrin:
2,405
Centerline:
Thanks. That's a good find. For years DC4 had been the go to grease in the electronics world where I worked.
My concern was once burned shame on them. Twice burned shame on me.
The problem I referred to was expensive.
Ken
