Best Method to Secure 3 Galley Draws - 42 Hunter Passage
3
Hunter 42 Passage Alameda, CA
The 3 galley draws on my 42 Hunter Passage always find a way to open during rough sailing. I know there is a metal catch (metal band) on the end of the draw track, but this does not provide sufficient tension to keep the draws closed. Has anyone found a good solution to keep the 3 draws closed?
Oct 14, 2005
2,191
Ted...
I put little pieces of plastic "post and claw" closures on the edge of each of my four galley drawers. I also have a long bungee that stretches up over them in case "someone" forgets to give them a good shove to engage the grippy things prior to setting sail.
