I also have a Vega series III (Spray-3339) and am rewiring her after having replaced the MD7A with a Beta 14.I keep the batteries in the original position but made a simple wooden double cross structure to hold them in place in case of capsizing and will add 2 battery fuses (160 amp) close by. I will use tinned cables of generous size at all levels. Switch panel/s with fuses: the location under the companionway doesn't look the best because of exposure, as you mention, but also because the wooden panel where it should be fixed has to be removed to access the engine compartment (unless modifications to the original system). I will put 2 6-switch panels, one per side, at the rear part of the shelf, over the main cabin berths. I purchased panels with blade fuses (better than cylinder type and easy to replace): I prefer them to magneto-termic to keep the system as simple as possible.I have replaced all bulb lights with leds and removed the fridge. One 50 W solar panel should cover all my needs (lights, charging iPhone and iPad (I use the iPad for navigation). I do not know if it will be enough to charge also my MAC 13. I have purchased a battery monitor (NASA, Clipper BM-1) but not yet mounted.Fair winds and following seas!marco, Albin Vega Spray - 3339 From: "gene_neill@... [AlbinVega]"
AlbinVega@yahoogroups.com To:
AlbinVega@yahoogroups.com Sent: Friday, 7 July 2017, 4:43 Subject: [AlbinVega] Best location for breaker panel
Opinions, please? I am planning a complete rewire of #3360, therefor anything can be anywhere I want it. and it seems to me that the companionway, being so exposed, could not be the best possible location for the breaker panel. Has anyone relocated theirs? Or wanted to? If you could wave a magic wand and move it anywhere, where would you put it and why?Also, I wonder about the wisdom of my boat's batteries being located in the bilge. Great for stability, but not so great if you took on enough water to fill the keel and submerge the terminals. Any thoughts?Thanks - and please use small, simple words because I am still an electrical dunce (electridiot?). I have some books on the subject I'm slowly working through. So much I need to learn.
#ygrps-yiv-1285834725 #ygrps-yiv-1285834725yiv5874746278 #ygrps-yiv-1285834725yiv5874746278 --
#ygrps-yiv-1285834725yiv5874746278ygrp-mkp {
border:1px solid #d8d8d8;font-family:Arial;margin:10px 0;padding:0 10px;}
#ygrps-yiv-1285834725 #ygrps-yiv-1285834725yiv5874746278 #ygrps-yiv-1285834725yiv5874746278ygrp-mkp hr {
border:1px solid #d8d8d8;}
#ygrps-yiv-1285834725 #ygrps-yiv-1285834725yiv5874746278 #ygrps-yiv-1285834725yiv5874746278ygrp-mkp #ygrps-yiv-1285834725yiv5874746278hd {
color:#628c2a;font-size:85%;font-weight:700;line-height:122%;margin:10px 0;}
#ygrps-yiv-1285834725 #ygrps-yiv-1285834725yiv5874746278 #ygrps-yiv-1285834725yiv5874746278ygrp-mkp #ygrps-yiv-1285834725yiv5874746278ads {
margin-bottom:10px;}
#ygrps-yiv-1285834725 #ygrps-yiv-1285834725yiv5874746278 #ygrps-yiv-1285834725yiv5874746278ygrp-mkp .ygrps-yiv-1285834725yiv5874746278ad {
padding:0 0;}
#ygrps-yiv-1285834725 #ygrps-yiv-1285834725yiv5874746278 #ygrps-yiv-1285834725yiv5874746278ygrp-mkp .ygrps-yiv-1285834725yiv5874746278ad p {
margin:0;}
#ygrps-yiv-1285834725 #ygrps-yiv-1285834725yiv5874746278 #ygrps-yiv-1285834725yiv5874746278ygrp-mkp .ygrps-yiv-1285834725yiv5874746278ad a {
color:#0000ff;text-decoration:none;}
#ygrps-yiv-1285834725 #ygrps-yiv-1285834725yiv5874746278 #ygrps-yiv-1285834725yiv5874746278ygrp-sponsor #ygrps-yiv-1285834725yiv5874746278ygrp-lc {
font-family:Arial;}
#ygrps-yiv-1285834725 #ygrps-yiv-1285834725yiv5874746278 #ygrps-yiv-1285834725yiv5874746278ygrp-sponsor #ygrps-yiv-1285834725yiv5874746278ygrp-lc #ygrps-yiv-1285834725yiv5874746278hd {
margin:10px 0px;font-weight:700;font-size:78%;line-height:122%;}
#ygrps-yiv-1285834725 #ygrps-yiv-1285834725yiv5874746278 #ygrps-yiv-1285834725yiv5874746278ygrp-sponsor #ygrps-yiv-1285834725yiv5874746278ygrp-lc .ygrps-yiv-1285834725yiv5874746278ad {
margin-bottom:10px;padding:0 0;}
#ygrps-yiv-1285834725 #ygrps-yiv-1285834725yiv5874746278 #ygrps-yiv-1285834725yiv5874746278actions {
font-family:Verdana;font-size:11px;padding:10px 0;}
#ygrps-yiv-1285834725 #ygrps-yiv-1285834725yiv5874746278 #ygrps-yiv-1285834725yiv5874746278activity {
background-color:#e0ecee;float:left;font-family:Verdana;font-size:10px;padding:10px;}
#ygrps-yiv-1285834725 #ygrps-yiv-1285834725yiv5874746278 #ygrps-yiv-1285834725yiv5874746278activity span {
font-weight:700;}
#ygrps-yiv-1285834725 #ygrps-yiv-1285834725yiv5874746278 #ygrps-yiv-1285834725yiv5874746278activity span:first-child {
text-transform:uppercase;}
#ygrps-yiv-1285834725 #ygrps-yiv-1285834725yiv5874746278 #ygrps-yiv-1285834725yiv5874746278activity span a {
color:#5085b6;text-decoration:none;}
#ygrps-yiv-1285834725 #ygrps-yiv-1285834725yiv5874746278 #ygrps-yiv-1285834725yiv5874746278activity span span {
color:#ff7900;}
#ygrps-yiv-1285834725 #ygrps-yiv-1285834725yiv5874746278 #ygrps-yiv-1285834725yiv5874746278activity span .ygrps-yiv-1285834725yiv5874746278underline {
text-decoration:underline;}
#ygrps-yiv-1285834725 #ygrps-yiv-1285834725yiv5874746278 .ygrps-yiv-1285834725yiv5874746278attach {
clear:both;display:table;font-family:Arial;font-size:12px;padding:10px 0;width:400px;}
#ygrps-yiv-1285834725 #ygrps-yiv-1285834725yiv5874746278 .ygrps-yiv-1285834725yiv5874746278attach div a {
#ygrps-yiv-1285834725 #ygrps-yiv-1285834725yiv5874746278 .ygrps-yiv-1285834725yiv5874746278attach img {
border:none;padding-right:5px;}
#ygrps-yiv-1285834725 #ygrps-yiv-1285834725yiv5874746278 .ygrps-yiv-1285834725yiv5874746278attach label {
display:block;margin-bottom:5px;}
#ygrps-yiv-1285834725 #ygrps-yiv-1285834725yiv5874746278 .ygrps-yiv-1285834725yiv5874746278attach label a {
#ygrps-yiv-1285834725 #ygrps-yiv-1285834725yiv5874746278 blockquote {
margin:0 0 0 4px;}
#ygrps-yiv-1285834725 #ygrps-yiv-1285834725yiv5874746278 .ygrps-yiv-1285834725yiv5874746278bold {
font-family:Arial;font-size:13px;font-weight:700;}
#ygrps-yiv-1285834725 #ygrps-yiv-1285834725yiv5874746278 .ygrps-yiv-1285834725yiv5874746278bold a {
#ygrps-yiv-1285834725 #ygrps-yiv-1285834725yiv5874746278 dd.ygrps-yiv-1285834725yiv5874746278last p a {
font-family:Verdana;font-weight:700;}
#ygrps-yiv-1285834725 #ygrps-yiv-1285834725yiv5874746278 dd.ygrps-yiv-1285834725yiv5874746278last p span {
margin-right:10px;font-family:Verdana;font-weight:700;}
#ygrps-yiv-1285834725 #ygrps-yiv-1285834725yiv5874746278 dd.ygrps-yiv-1285834725yiv5874746278last p span.ygrps-yiv-1285834725yiv5874746278yshortcuts {
margin-right:0;}
#ygrps-yiv-1285834725 #ygrps-yiv-1285834725yiv5874746278 div.ygrps-yiv-1285834725yiv5874746278attach-table div div a {
#ygrps-yiv-1285834725 #ygrps-yiv-1285834725yiv5874746278 div.ygrps-yiv-1285834725yiv5874746278attach-table {
width:400px;}
#ygrps-yiv-1285834725 #ygrps-yiv-1285834725yiv5874746278 div.ygrps-yiv-1285834725yiv5874746278file-title a, #ygrps-yiv-1285834725 #ygrps-yiv-1285834725yiv5874746278 div.ygrps-yiv-1285834725yiv5874746278file-title a:active, #ygrps-yiv-1285834725 #ygrps-yiv-1285834725yiv5874746278 div.ygrps-yiv-1285834725yiv5874746278file-title a:hover, #ygrps-yiv-1285834725 #ygrps-yiv-1285834725yiv5874746278 div.ygrps-yiv-1285834725yiv5874746278file-title a:visited {
#ygrps-yiv-1285834725 #ygrps-yiv-1285834725yiv5874746278 div.ygrps-yiv-1285834725yiv5874746278photo-title a, #ygrps-yiv-1285834725 #ygrps-yiv-1285834725yiv5874746278 div.ygrps-yiv-1285834725yiv5874746278photo-title a:active, #ygrps-yiv-1285834725 #ygrps-yiv-1285834725yiv5874746278 div.ygrps-yiv-1285834725yiv5874746278photo-title a:hover, #ygrps-yiv-1285834725 #ygrps-yiv-1285834725yiv5874746278 div.ygrps-yiv-1285834725yiv5874746278photo-title a:visited {
#ygrps-yiv-1285834725 #ygrps-yiv-1285834725yiv5874746278 div#ygrps-yiv-1285834725yiv5874746278ygrp-mlmsg #ygrps-yiv-1285834725yiv5874746278ygrp-msg p a span.ygrps-yiv-1285834725yiv5874746278yshortcuts {
font-family:Verdana;font-size:10px;font-weight:normal;}
#ygrps-yiv-1285834725 #ygrps-yiv-1285834725yiv5874746278 .ygrps-yiv-1285834725yiv5874746278green {
color:#628c2a;}
#ygrps-yiv-1285834725 #ygrps-yiv-1285834725yiv5874746278 .ygrps-yiv-1285834725yiv5874746278MsoNormal {
margin:0 0 0 0;}
#ygrps-yiv-1285834725 #ygrps-yiv-1285834725yiv5874746278 o {
font-size:0;}
#ygrps-yiv-1285834725 #ygrps-yiv-1285834725yiv5874746278 #ygrps-yiv-1285834725yiv5874746278photos div {
float:left;width:72px;}
#ygrps-yiv-1285834725 #ygrps-yiv-1285834725yiv5874746278 #ygrps-yiv-1285834725yiv5874746278photos div div {
border:1px solid #666666;min-height:62px;overflow:hidden;width:62px;}
#ygrps-yiv-1285834725 #ygrps-yiv-1285834725yiv5874746278 #ygrps-yiv-1285834725yiv5874746278photos div label {
color:#666666;font-size:10px;overflow:hidden;text-align:center;white-space:nowrap;width:64px;}
#ygrps-yiv-1285834725 #ygrps-yiv-1285834725yiv5874746278 #ygrps-yiv-1285834725yiv5874746278reco-category {
font-size:77%;}
#ygrps-yiv-1285834725 #ygrps-yiv-1285834725yiv5874746278 #ygrps-yiv-1285834725yiv5874746278reco-desc {
font-size:77%;}
#ygrps-yiv-1285834725 #ygrps-yiv-1285834725yiv5874746278 .ygrps-yiv-1285834725yiv5874746278replbq {
margin:4px;}
#ygrps-yiv-1285834725 #ygrps-yiv-1285834725yiv5874746278 #ygrps-yiv-1285834725yiv5874746278ygrp-actbar div a:first-child {
margin-right:2px;padding-right:5px;}
#ygrps-yiv-1285834725 #ygrps-yiv-1285834725yiv5874746278 #ygrps-yiv-1285834725yiv5874746278ygrp-mlmsg {
font-size:13px;font-family:Arial, helvetica, clean, sans-serif;}
#ygrps-yiv-1285834725 #ygrps-yiv-1285834725yiv5874746278 #ygrps-yiv-1285834725yiv5874746278ygrp-mlmsg table {
font-size:inherit;font:100%;}
#ygrps-yiv-1285834725 #ygrps-yiv-1285834725yiv5874746278 #ygrps-yiv-1285834725yiv5874746278ygrp-mlmsg select, #ygrps-yiv-1285834725 #ygrps-yiv-1285834725yiv5874746278 input, #ygrps-yiv-1285834725 #ygrps-yiv-1285834725yiv5874746278 textarea {
font:99% Arial, Helvetica, clean, sans-serif;}
#ygrps-yiv-1285834725 #ygrps-yiv-1285834725yiv5874746278 #ygrps-yiv-1285834725yiv5874746278ygrp-mlmsg pre, #ygrps-yiv-1285834725 #ygrps-yiv-1285834725yiv5874746278 code {
font:115% monospace;}
#ygrps-yiv-1285834725 #ygrps-yiv-1285834725yiv5874746278 #ygrps-yiv-1285834725yiv5874746278ygrp-mlmsg * {
line-height:1.22em;}
#ygrps-yiv-1285834725 #ygrps-yiv-1285834725yiv5874746278 #ygrps-yiv-1285834725yiv5874746278ygrp-mlmsg #ygrps-yiv-1285834725yiv5874746278logo {
padding-bottom:10px;}#ygrps-yiv-1285834725 #ygrps-yiv-1285834725yiv5874746278 #ygrps-yiv-1285834725yiv5874746278ygrp-msg p a {
font-family:Verdana;}
#ygrps-yiv-1285834725 #ygrps-yiv-1285834725yiv5874746278 #ygrps-yiv-1285834725yiv5874746278ygrp-msg p#ygrps-yiv-1285834725yiv5874746278attach-count span {
color:#1E66AE;font-weight:700;}
#ygrps-yiv-1285834725 #ygrps-yiv-1285834725yiv5874746278 #ygrps-yiv-1285834725yiv5874746278ygrp-reco #ygrps-yiv-1285834725yiv5874746278reco-head {
color:#ff7900;font-weight:700;}
#ygrps-yiv-1285834725 #ygrps-yiv-1285834725yiv5874746278 #ygrps-yiv-1285834725yiv5874746278ygrp-reco {
margin-bottom:20px;padding:0px;}
#ygrps-yiv-1285834725 #ygrps-yiv-1285834725yiv5874746278 #ygrps-yiv-1285834725yiv5874746278ygrp-sponsor #ygrps-yiv-1285834725yiv5874746278ov li a {
font-size:130%;text-decoration:none;}
#ygrps-yiv-1285834725 #ygrps-yiv-1285834725yiv5874746278 #ygrps-yiv-1285834725yiv5874746278ygrp-sponsor #ygrps-yiv-1285834725yiv5874746278ov li {
font-size:77%;list-style-type:square;padding:6px 0;}
#ygrps-yiv-1285834725 #ygrps-yiv-1285834725yiv5874746278 #ygrps-yiv-1285834725yiv5874746278ygrp-sponsor #ygrps-yiv-1285834725yiv5874746278ov ul {
margin:0;padding:0 0 0 8px;}
#ygrps-yiv-1285834725 #ygrps-yiv-1285834725yiv5874746278 #ygrps-yiv-1285834725yiv5874746278ygrp-text {
font-family:Georgia;}
#ygrps-yiv-1285834725 #ygrps-yiv-1285834725yiv5874746278 #ygrps-yiv-1285834725yiv5874746278ygrp-text p {
margin:0 0 1em 0;}
#ygrps-yiv-1285834725 #ygrps-yiv-1285834725yiv5874746278 #ygrps-yiv-1285834725yiv5874746278ygrp-text tt {
font-size:120%;}
#ygrps-yiv-1285834725 #ygrps-yiv-1285834725yiv5874746278 #ygrps-yiv-1285834725yiv5874746278ygrp-vital ul li:last-child {
border-right:none !important;}
