best lube
My poor Cat 30 has been sitting at the dock neglected for about 4 years. Trying to bring her back to life.We thought the engine was dead from overheating. Got her back up and running. Obviously having to do some major maintenance.Everything that moved on her is stiff or stuck. Need advice on best lube for traveler track, blocks, hydraulic boom vang,wenches,furling system, steering cables and such...Had to replace the diesel tank due to pin hole leaks. Anything else I should look for on her that commonly goes bad when left to rot due to a divorce?Thanks in advance for your help. She will sail again!!!!!!!
