Considering myself lucky, that you shared some "insider" information about your boat and your climate in a past PM.
Reviewing the nice interior pictures of you boat, believe I can see the scupper cockpit drain lineon the forward cockpit, port side. Assuming I am right, I have the following thoughts:
1) Galley sink top has to be lower than the near bottom of your cockpit. [seacock closed proof]
2) The bottom of the Galley sink is above the Water Level of your boat [seacock open proof]
3) The common drain therefore is under the cabinets and deck boards, most likely laying on inner hull.
4) With your cabin closed, and minimum air flow inside, the lines have no direct exterior air exposure.
Yeah yeah Jim, so what?
The water in your marina is no less than 40°F and my guess nearer 55°F at the coldest [not at surface] but under water, like the submerged hull of your boat.
Therefore...
The cabin of your boat and especially the drain line under the flooring deck, is near the Water Temperatures and essentially "stagnant air insulated"!!
I can safely predict [since I know you are insured
The lines of concern will
NOT Freeze, while you boat is afloat in your marina.
Jim...
PS: The best insulation is Stagnant [ not smelly but mean not moving] Air.
