Agree with Used version...
Don't know where your from or where your looking at boats, but Ron will probably tell you in his experience with boat searching, a freshwater boat is probably in a little better condition than a life-long saltwater boat DEPENDING on the care of the owners. If you can find the model you want (or a choice of two or three) you might find a great used boat for a little more money but with less usage than a boat on the coast. Here's some things you should consider:1. How old are the kids? Can they sleep together in a V-berth or will they require "their own space"? If you have a teenage daughter you will need two heads. Then again, a second head is always good as it gives somebody a place for total privacy without making the crew uncomfortable. (Smallest model with two heads is 376)2. Will you be showering on-board? (Since you said liveaboard cruiser, I assume you will) If so, a separate shower stall is, in my very humble opinion, an absolute requirement. (Smallest model with separate shower compartment is 376.)3. What kind of cruising toys/equipment do you want? If you're into scuba and want to take your own equipment, you need a boat with huge lazarettes. (Not available on the 376 compared to other models.)4. HOW much privacy do you and your wife require for "whatever", "naps" etc? If you like a bit more privacy than an open space, you will want a stateroom. (H37 is smallest model with completely seperate stateroom with suitable doors at the farthest possible location from the V-berth and open salon, which can be used for sleeping. 376 is also good at this.)5. Will you need on-board generator for electrical power? (Please revisit the teenage daughter issue.) If so, you want to consider the generator's location, maintenance, cost, etc. (Have seen after-market generators inistalled on units as small as 29'.)6. Going to be swimming a lot? (Please revisit scuba gear issue.) If so, and you will be handing equipment, gear, fish, people, etc. from water level into the boat, any model with builtin stern steps is easier to work with than a stern ladder. (376 also has stern steps.)7. going to be motoring a lot? Pick the model with the best fuel tankage to hp/usage ratio or be prepared to expand the capacity or carry jerry jugs.8. Got milk? Will you need to have lots of refridgeration or will you hump blocks of ice down the pier every few days? Pick a model with refridgeration as standard if you think you need it.Well, that gives you an idea of what to look for. If you don't find something in one model, look at another or one size up. Of course, as with everything with boats, it's a compromise: cost, comfort, performance, amenities, etc. That's the great thing about Hunter, lots of choices.
