Try VC17m
Your location is listed as Springfield, MO, so assume that you are in fresh water.You may be just fine without an anti fouling paint, it is best to ask for advice from local sources. Conditions can vary depending on location, even on the same lake.I used to keep a boat on Lake Winnipesaukee (NH) and didn't use bottom paint at my location that had fairly deep, cool water. The slime would come off pretty easily with a power washer at the end of the season, and mid season I would spend a few hours snokling with a scrub brush to take off the slime. Other parts of the lake were shallow, warm and weedy and boats moored there required paint to keep the weeds at bay.A popular one for fresh water is Interlux VC17m.Anti fouling paints will not seal the bottom to prevent blistering. If this is required, Interlux also makes a barrier paint called VC-Tar2 that is compatible with the VC17m.Getting a boat up off the trailer, preping the bottom (very important) and painting are jobs I leave to the boat yard professionals. They have the equipment and experience to do a good job, safely and without environmental impact. These paints are hazardous and you want to handle them carefully to avoid breathing fumes and getting it on your skin. Even the dust from old paint while doing bottom prep is hazardous.My boat is now in Boston Harbor and I use Woolsey Hydrocoat. It is a water based, multi season ablative, and I get 2 seasons between paint jobs. I have the boat yard prep the bottom and apply 2 coats. In between years I touch up the nicks as best I can on the trailer.Fair winds...Tom
