best bottom paint for fresh water, hunter 26
Max.C
Jun 7, 2021
4
Hunter 260 Ottawa
folks, i am spending about 6 months in the water. its a fresh water river. can you advise some good but reasonably priced bottom paint that i dont need to reapply every season preferably?
Apr 27, 2010
1,279
Hunter 23 Lake Wallenpaupack
Check with experienced boaters in your area. We kept our 23 in a lake and never had to use antifouling paint, left hull bare. We only got a thin layer of mossy type stuff that the yard blasted off with monster pressure washer at end of season.
Likes: Max.C
DArcy
Feb 11, 2017
1,777
Islander Freeport 36 Ottawa
The majority of boats on wet moorings here use VC-17. I'm not sure how well it holds up out of the water, I've heard it is best to splash within a few days of painting with VC-17 but the data sheet doesn't say anything about this and I have seen several boats prepped and painted in the fall, left over the winter and still had good results. If you are dry sailing, there won't be much time for growth anyway and VC-17 is really easy to clean growth off, even a wet sponge will clean it up.
Likes: danstanford
Jul 5, 2022
4
J-Boat J30 Perry Lake
I recommend VC-17. An ablative paint will rub off where bunk boards or pads are located.
May 10, 2004
254
Hunter MH 37 Manitowoc, WI
We used VC-17 during our 16 years with our H26. It will require annual repainting in the spring. A good pressure wash and a like scuffing with a scotch-brite pad is all the prep you need. Be aware that it cannot be overcoated with any other paint and will require stripping before you can use any other paint. We never had a fouling issue or zebra mussels. The newer VC-17M also keeps the slime from building up.
Jun 14, 2004
169
Hunter 260 Portland, OR
Owned our 260 since 2004. Sits in Columbia River for 6 months at a time. Pull it every season for six months on the trailer. Use professionally applied Pettit Ultima SR60 ablative. It's halfway through its third bottom paint job in 18 years. Never had a problem with bunks chafing the paint off. We don't clean bottom when we pull the boat to avoid reducing paint effectiveness.
1,165
Leopard 40 Jupiter, Florida
I used Pettit Vivid on my trailer sailor that would sit in fresh water for a season in Michigan. At the time it was the only one that would allow repeated drying / re-wetting and still kept killing things. I'd crawl under the trailer in the spring and touch up the bare spots, but never really had to re-coat everything. VC17 probably would work as well, but I'm not certain that it would keep killing after drying out all winter. It's certainly very tender, so at least the trailer bunk area would be down to bare hull.
Feb 26, 2011
1,440
Achilles SD-130 Alameda, CA
We used VC-17 during our 16 years with our H26. Be aware that it cannot be overcoated with any other paint and will require stripping before you can use any other paint.
Not true. VC17 is compatible with other teflon-based anti fouling paints.
