Best anchor for the Cheasapeake Bay
Dec 18, 2012
160
Hunter 37.5 Annapolis
My Danforth style Fortress anchor isn't cutting it lately. I've had a hard time setting in Oxford, St Micheals, and several other places. A Fortress worked well on my previous boat, but not on my current one. I don't have faith in it any more, which makes sleeping difficult.
What anchor have you Bay sailors had good experience with?
Beneteau 323 Annapolis MD
I use a CQR 35 on my B323. It holds me on my own or in a linear or circle raftup where I am the 12 o'clock boat. 5/16 chain.
Mar 26, 2011
3,677
Corsair F-24 MK I Deale, MD
Before we get into "right anchor" debates, which you can easily search, please explain your set-up and procedure. There maybe a difference. The Fortress should set in mud, so something is wrong. Even if you get a new anchor, you should be able to set the Fortress reliably as a secondary, so let us learn what went wrong.
Back Creek in Oxford has heavy weed in some areas, which could be a problem.
Because Fortress anchors are light they require specific techniques:
* NOT heavy chain. It will drag the shank down.
* Hand-set if possible.
* An initial very light set at short scope often helps.
Once set, they hold like nothing else in mud.
Feb 8, 2017
108
MacGregor MacGregor 25 Middle River
I use a 30 year old 20 pound Danforth with 3 feet of chain and the rest nylon 3 strand. It's held in every situation that I've ever deployed it for (knock on wood!!), including a few raging Chesapeake Bay storms. And even though I was holding onto the boat for dear life, my anchor and rig stayed dug-in while everyone else in the anchorage dragged past me. Having enough scope is pretty darn important!! That, and taking the time to make sure you're set properly. I've seen so many folks over the years who just drop anchor and leave the anchor line hanging nearly straight down - not so good in a crowded field.
Dec 18, 2012
160
Thinwater,
I have 20 feet of chain, vs 6ft on my old boat. I do hand set, paying out slowly as the boat drifts downwind, and typically shoot for 7:1 scope.
Too much chain is an interesting comment. The PO had no chain and a bent West Marine danforth. I'll try without the chain next visit to St Michaels.
I also have a Bruce anchor that came with the boat that I could try.
.... I'll try without the chain next visit to St Michaels.
Do you anchor in the river or the back-door creek? A couple guys just told me they'd never anchor in the river again- to much traffic on a weekend.
Dec 18, 2012
160
We usually anchor in the little creek to starboard as you head in towards the museum, just off the Inn at Perry Cabin. Last visit we couldn't hold there, couldn't hold near "4SM", and couldn't hold in the river off Parrot Point until we tried in 20' depth. We prefer to anchor off Perry Cabin so that we can explore the creek in kayaks and easily get to the museum.
We have anchored in San Domingo Creek, which gets you into town right by Eastern Shore Brewing (get the St Michaels Ale!!), but we belong to the museum, so prefer to be close to that.
SG
Feb 11, 2017
1,670
J/Boat J/160 Annapolis
With that chain, which I think is fine, I try to set the anchor initially with a 2:1 scope (real, from your fore deck to the bottom).
The "too much" chain issue with the shank down is an interesting observation -- I'm not sure I agree once it set, but I've found that trying an initial set with not so much scope out is better for a variety of reasons. Those include the bigger pain to reset so much scope that you have to pull in (with it's mud, clay, or whaterver); and, I think the initial dig into the bottom works at about 2: or 3:1. After you've got it "hooked" or "buried a bit", you can really bury the anchor.
Long ago, we had a Pearson 35 (center boarder) and used to enjoy that creek near the Inn at Perry Cabin (before Lord Ashley turned into an high-end retreat/resort). That Creek has VERY, VERY, SOFT MUD. I've seen a lot of people that found that Creek to be a challenge to get holding in.
Gunni
Mar 16, 2010
5,937
If you are out in the Tred Avon river at Oxford you will experience a sandy bottom in many places and between reversing current, wake and wind change, more than the average amount of swing at anchor. The Danforth/Fortress tends to roll and pull out and drag when it gets veered. Keep it as a kedge and backup anchor for those times when you face the inevitable - running aground at Oxford!
Sep 23, 2009
1,475
Same on our 34. Have been caught several times in 25 knot winds with 180 degree shifts and no problem. Only 8 feet of chain and 5 or 6 to one scope. On last years club cruise we and another boat with a cqr were the only boats that had no problem setting the anchor. If I someday sell the boat, the anchor stays with me!
Apr 20, 2012
21
Sorry to hear of your issues, please try this:
• Permanently install the Mud Palms, which were included inside of the box with the anchor if you bought it disassembled. The Mud Palms will lift the back end of the anchor up so that the Flukes will take a more aggressive angle into the bottom.
• In soft mud, use a shorter scope when initially setting the anchor. This will keep the chain from sinking the chain below the flukes, as per the image below:
Once the anchor sets, then let out a 5:1 scope and "power set" the anchor by backing down on it.
I hope this helps!
Gunni
Mar 16, 2010
5,937
Good point on that power set recommendation. When someone anchors near me I keep an eye on their technique. Many if not most people setting an anchor fail to do a proper power set. Because the Fortress anchor sets so aggressively you can pull it deep in the mud and greatly improve your set. Center your rudder and back down to full throttle and hold it for 1 minute. If you move, you have a bad set.
Likes: Fortress
May 23, 2004
3,319
There is no magic bullet when it comes to anchors. Anchor threads tend to get a lot of heated debate and a lot of people think that they have the perfect anchor. It is best to carry a few anchors and I like to upsize mine.
In the end, if you don't back down on the anchor it doesn't really matter what you have. Others have posted about this and they are 100% right. If you can back down on it hard and it doesn't move, you are probably okay.
I did use a Lewmar Claw on my boats with 30' of chain (1 foot of chain per foot of boat at a minimum). It held okay and never gave me an issue for setting or resetting, even in those crazy 180 degree wind changes from a storm that the Chesapeake Bay is famous for. If I was spending money to sleep better, I would look at the Rocna or the Manson Supreme. I had a friend that swore by his and he went from the Chesapeake to the Bahamas and back a few times.
Sep 15, 2013
708
Catalina 270 Baltimore
Can you have too much chain? I have never heard that before until now. Inquiring minds want to know.
Nov 26, 2012
2,315
Catalina 250 Bodega Bay CA
Don't see anything about too much chain. BO is informing you that the basic rule of thumb most of us use is a MINIMUM of length of chain matching length of boat. Chief
