Bent turnbuckle bolts on forward shrouds?
Brandon Pellow
I understand that it is fairly common when stepping the mast to bend the "T" bolts that attach the shrouds to the deck. I need to replace the bolts only as I am not interested in buying several new turbuckles solely for one threaded "T" bolt. I have searched the Catalina Direct book and cannot find just the bolts. There is a article in the helpful hints section which discusses how common this problem is but doesn't address fixing it beyond replacing the whole turnbuckle. Does anybody know where these can be purchased individually? Thank You in advance Brandon
john renfro
bent
west marine sells the t bolt without the turnbuckle or the other end. www.westmarine.com. john
