Jon Larson
My 2005 Catalina 22 Sport, a new left over, was delivered a couple of weeks ago. The starboard aft lower shroud turnbuckle bolt and the starboard upper shroud turnbuckle bolt were bent. The dealer sent me new bolts and turnbuckles.I could loosen the lower shroud turnbuckle and get slack to disconnect the turnbuckle and replace the bolt and toggle. No problem.I unscrewed the upper shroud as far as I dared before it could spring apart and tension never left the shroud. I went to the opposite upper port shroud and unscrewed that turnbuckle as much as I dared, and neither shroud ever went slack. It sure seems to me the mast has to come down in order to replace the upper bolt and toggle, am I right in thinking that?I must say, the rigging is really tight for this boat, tighter than I remember my previous sail boats being.Jon
