Paul
I just bought a used 97' 26x and to make a long storyshort, I drop the mast 6' before the mast was on the crutch, It now has a slight bend, which is about 5'up from the bottom of the mast. this put the top of the mast about one foot out of plum. Its hard to see on the ground but when I put it up, its quite obvious.can this be repaired, or should I retire it as a flag pole. and if so where would I fine a replacement.Paul
