While I haven't heard of a bent I-beam, a corroded/eroded I-beam seems quite common. I'd think both pose a similar risk. There are posts on the subject with a range of 'fixes'. In addition to many others, some suggest removing the wood post and steel i-beam and replacing completely (after repairing any deck compression of course!) with a stainless post arrangement (certainly seems the best long-term solution).
In my case, I fabricated a new I-beam piece, coated and epoxied into place - thereby utilizing the same setup above (wood post, trim, etc.). I figure if the original I-beam lasted 30+ years, a new protected one should outlast the boat. The most difficult/dirty part of the job was removing the epoxy holding the base of the I-beam in place. For me it was a hacksaw, hammer and chisel along with guesswork. Costs were minimal since the materials were lying around - just a bit of epoxy/filler really. It was worth the repair.
The base of the I-beam is tapered forward. I don't have any photos with me, but I should have access to some later next week if interested.
