Benny 331 - jabsco shower pump
14
Beneteau 331 Penetanguishine
Our boat is 10 years old this year so there is wear & tear and systems/processes need to be updated.
Our shower pump isn't doing what it used to..
I have cleaned out the screens of debris, tried dumping drano, pushed a coat hanger through head floor drain.
Any thoughts on issue/solution?
Would rather spend money on making boat go faster or look better versus internal plumbing :)
Greg
ROCKET LAWNCHAIR
Bum
Mar 18, 2008
35
Beneteau 331 w/swing keel New Gretna, NJ, Bass River
Is your shower pump also connected to your refrig drain? Has the switch over handle been moved at all?Does the refrig drain with the pump?There may be a clog in that valve or your impeller may be shot.Good Luck.
Ron M
Mar 21, 2010
67
Beneteau 331 Rock Hall, MD
Perhaps the pump diaphram might need to be replaced. I had a fresh water pump (Shurflo) problem and found small pieces of plastic wedged in the diaphram.
Jun 24, 2011
14
All good!
Took it all apart and found small pieces of plastic and assorted crud blocking lines to the pump itself.
Thanks for advice.
Greg
