No way! It's just the price of a battery "upgrade" although some might not call AGM's an upgrade! I had AGM's and don't think they're suitable for cruising. Went back to flooded batteries. AGM's like to be fully charged and that is difficult to do when cruising.The price may include a high output aftermarket alternator. The AGM install should include one. The Beneteau house battery tray has limited space, so getting a high amp acceptance 220 Ah AGM is a great option. You can drain it lower and charge it 4 times faster than a similar sized flooded lead acid (which MAY provide 200 Ah)
The standard Yanmar alternator isn't a good match for AGM use. Too little amperage at idle and cruise speeds.No way! It's just the price of a battery "upgrade" although some might not call AGM's an upgrade! I had AGM's and don't think they're suitable for cruising. Went back to flooded batteries. AGM's like to be fully charged and that is difficult to do when cruising.
Running a Balmar 100 amp small case and smart regulator. Not a question of too little amperage and cruise speed. What the problem is is that when you're cruising you spend a lot of time at anchor. Batteries are usually discharged to 50% and when charging it just takes forever and is not economical to get the final 15% in. So you are using from 85% to 50 %. The batteries seldom get fully charged and AGM's don't like this. I switched back to flooded batteries and they are much better for cruising. If you're in a slip and on shorepower it really makes little difference what batteries you use but when cruising it makes all the difference.The standard Yanmar alternator isn't a good match for AGM use. Too little amperage at idle and cruise speeds.
Your bank should be ideally be sized the same whether you are installing AGM, GEL or WET lead acid batteries. With Li technology $$$$$$$ you can go smaller.Thanks Gordon, I'm actually looking at shrinking my house from 400Ah to 300Ah with a move to AGM.
Wet cells can also be deeply cycled but common accepted depth for deep cycling is to not cycle the battery, whether AGM, GEL or WET to any deeper than 50%. The AGM makers all claimed that early on, and some still do, it was safe to go to 80% DOD, but when you cut through the marketing BS they all really recommend not cycling any deeper than 50%. Lifeline & Deka the two largest makers of AGM batteries used in the marine market both advise cycling to a max depth of 50% for the longest life.AGMs are rated for drawdown to 35% - that is a big advantage
In bulk mode this is true and one great benefit of AGM batteries. You can go from 50% to 85% much faster than with wets but they still drastically limit charging at 80% SOC and beyond so getting to full is still just as elusive with AGM's as it is with wets if off cruising.- you can then dump large amperage, longer during charge. The reserve capacity for normal house draws are also much better.
Being in a slip is very good for AGM batteries as they love to get back to full as often as possible.I do slip the boat, and I also have a genset that I would use with an upgraded battery charger to dump the large amperage the AGM battery can accept. If I was not in a slip I would definitely install a solar panel.
Believe I can get 300 Ah (2, 6vdc) AGM in the OEM battery location and with that get the extended drawdown to 35%, and at my 12 Ah drawdown the reserve capacity is 1200 minutes (a good 20 hours).
I have installed quite a few of these and they are great but really benefit from the serpentine pulley kit when you get over 80A. I really like the 140A units over the 120A as they are not much more money and they can run for many hours at 120A+. They also pump out some large current at very low RPM.I really like the power curve of the Electromaax 120 A alternator.
130 pounds of weight in battery, on a large vessel such as yours, can be good weight if properly placed.All this is still in the design stage - I just really want to shed 130lbs of battery in my locker.
That is just basic math but unfortunately skewed greatly by what I call non real world fantasy data. When AGM's first came on strong they too used lab derived data and pitched it as it would apply in the real world. It never does. I don't think I have seen many banks ever hit even 400 cycles in the real world let alone 2900 at 50% DOD or 1700 cycles at 80% DOD. For people who cycle to 80% DOD 1-2 seasons is more real world.. Going to 50% DOD then 5-6 years is more likely.Thanks for checking in on this Maine. Can you comment on two manufacturer claims:
- A Lifeline AGM will produce more total Amp hours in it's life at 80% drawdown than it will at 30% drawdown. http://www.electromaax.com/faq/#q6
I have been round and round with Rob & John on those curves. They SHOULD be based on alternator RPM not your engine RPM. They use a 2.25:1 ratio for that graph as they decided that was the most common ratio on marine engines. If you have less than 2.25:1 you will not get that output at 1300 engine RPM and if your ratio is higher than 2.25:1 you'll hit it earlier. They do pump out some serious current at low RPM.
- An Electromaax 120A alternator will produce 100+A at high idle speed(1300 rpm). http://www.electromaax.com/wp-content/themes/electromaax/_common/pdf/120AmpSpecs_SM.pdf
