Beneteau Moorings 38 Starboard Water Tank Leaking
Beneteau 38 Stone Mountain, Georgia GA
Listmates
I've found that the starboard water tank beneath the saloon settee is not holding water. It's a 35 gallon tank, original to my 1990 Beneteau Moorings 38. I believe the water fill and pickup are internal, which leads me to believe that the tank itself, rather than in- or out-bound hoses, is leaking. Has anyone ever encountered this before? Is it possible, assuming that I can find the leak, to patch the take material? Suggestions for patching compound (JB Weld comes to mind)?
Thanks, in advance, for any guidance.
Mike
S/V My Funny Valentine
Beneteau Moorings 38 #17
Lake Lanier, Georgia
pgood
Aug 27, 2007
1
Beneteau Moorings_38 Gulfport, FL
On the outside chance you are still monitoring this.... I have the same boat, and yes, the tank can be repaired if you find a crack. It's a "welding" process for whatever the tank is made of. I had work done to shorten the starboard tank for an A/C compressor. 10 years later the tank is fine.
Paul
S/V Bamboo
1991 Beneteau Moorings 38
Gulfport, FL
