Beneteau Fridge
287
Beneteau Oceanis 352 NYC
The fridge drain on my '98 352 seems to be clogged, does anyone know where the fridge is supposed to drain? I can't seem to get the water to flow and have tried snaking the drain to no avail....any suggestions would be appreciated.
I
ISPHH
pump
My 423 has a button for a pump to drain the fridge and I must open a thru-hole for it to drain. Others, like the a/c units, drain into the bilge for that pump to get rid of the water.
Jun 4, 2004
287
Ahhhhh....
Right! I will check to see if it's attached to the sink drain....
May 18, 2004
385
Catalina 320 perry lake
On my
OC 281, the bilge pump drains the bilge, the shower, and the ice box. There is a 3 valve manifold under the sink in my head. two valves have to be closed and one open for draining the desired thing. e.g. close shower and bilge valves to drain ice box, shut ice box and shower to pump bilge etc.
Jun 16, 2005
476
- - long beach, CA
fridge
The fridge on my '94 OC 400 doesn't have a drain. It has to be sponged out, but the freezer does. It's manifolded to the bilge pump with a selector valve under the settee.
