What's normal?
Is it normal to have a gap between the hull and keel on a 1984 First 42? The vessel in question was just hauled for survey. The surveyor noted a gap at the rear of the keel to hull of approximately 1/4". When he pushed his foot against the bottom of the keel water was observed coming out from along the keel/hull joint. Is this normal? The surveyor noted that at least 3 of the hull stiffeners that are fibreglassed to the hull, under the pre-formed skeletal stiffener, displayed cracks and that when stepped on water could be observed coming out. Is this normal? Additionally, while the vessel was still in the slings, the surveyor re-entered the vessel and noted the gaps under the aforementioned stringers now grew in size indicating the hull was being pulled down away from the stiffeners. Is this normal? If it IS normal, is it safe? Lastly, while pushing the prop-shaft to check the cutlass bearing for wear the entire support moved and water was observed coming from the support/hull joint. Is this normal?
Thanks to all who can voice their opinion and personal experience.
HN, RWC, CA
HN, RWC, CA
