Staszek
After 3 years sailing on a Hunter 23 it's time for me to make the step and I'm currently shopping for a second hand sailboat in the 35ft range.
I'm currently looking at two boats. A 1993 First 35S5 and a 1995 Oceanis 351.
The Oceanis is newer but has some issues. There is some crazing above and below the waterline and there is a crack in the mast (that has been welded once already but has come back).
According to the broker, the mast crack can be welded easily and the crazing is a typical Oceanis 351 problem as the hull is designed at the thin side.
This made me thinking about the 35S5. I understood that the First 35S5 is the predecessor of the Oceanis 351. Is there somebody that can enlighten me a bit more about any modifications in design that were made to change the 35S5 to the Oceanis 351?
Should I be worried that the 35S5 hull is designed too thin as well?
Any other comments or bad/good experiences with both models are very welcome.
Thanks in advance for your advice.
Staszek
Staszek
