Hi Folks,
So I went down and inspected the boat (thank you for the link about what to inspect). I saw no rotting under the floor boards, was unable to analyze the keel (since it's in the water); but, did manage to get a professional survey report from 2012 with no osmosis issues and no keel rusting issues. The boat probably requires new bottom paint.
The owners accepted the offer as-is and said there are two known issues: 1) Heat and 2) Windless
I was hoping you guys could take a look at the pictures I took to let me know if it seems like I am looking at bigger problems, here is what concerns me:
1) Some cracks on the aft side
2) Minor build-up near the plumbing area in the bathroom
3) Old pipe in the heating unit
4) Minor corrosion on the plate where the engine is bolted down
I figure if osmosis was an issue then the 2012 professionally done survey would indicate it. The likelihood of osmosis 3 years later is probably unlikely? So should I skip the buyers survey and save myself $800 which I can spend toward the heating issue and windless issue not to mention bottom paint? Or get it to be sure? I can upload the full survey as well it states all things in good working condition w/ the primary volvo engine only having 485 total service hours on it.
Pictures are here: http://imgur.com/a/ROpQd
