Beneteau battery switch
Aug 3, 2014
65
Beneteau 343 San Francisco Bay
Hmmmm, good comment, probably wouldn't have easily figured that out. So, instead of the handle feeling spring-loaded, did it just spin?
Nov 11, 2018
12
Beneteau 45F5 6 Melbourne, Victoria
In my case, it still felt like it was spring-loaded. The handle moved out and snapped into the open position however it was not far enough out to open the circuit.
NYSail
Jan 6, 2006
3,069
Beneteau 423 Mt. Sinai, NY
Gunni did/do you have the jumper cable between the two bank switches?
Gunni
Mar 16, 2010
5,937
Yes, my system is OEM. I have no problem with knowing to disconnect each battery bank (start, house) when not in use. I also keep my windlass breaker tripped until needed.
Aug 3, 2014
65
The house batteries work in tandem with both switches on; engine battery remains isolated. Unfortunately, this doesn't allow for house-battery charging while motoring. Nonetheless, 8 hrs of motoring the other day, and the small house battery showed no sign of fading.
Aug 3, 2014
65
Has already been mentioned, but remember, if you're using battery power while sailing (electronics, 'fridge, etc.) remember to open your engine battery switch. If you leave the engine switch closed, the engine battery will be drawn down at about the same percentage as the house batter y/ries because of the default electrical setup.
Just for the record, Beneteau has changed its switch wiring over the years. Our 2014 Oceanis 37 does not have a jumper between the switches. The two switches switch the house and start banks independently. There are voltage drop free isolators to combine the batteries when charging. It does still have the ground switch, which would be better repurposed as an emergency cross-over, allowing the house bank to start the engine in a pinch.
Aug 3, 2014
65
Davidasailor26, that sounds like the best of both worlds. Is there an easy-to-obtain schematic? Perhaps it would be worth considering this option, if not too expensive, on my somewhat older boat.
Beneteau 323 Annapolis MD
That's exactly what I always say: a switch per battery as on my B323 that I added a third battery & switch to. A batt goes bad, take it off line. Need more amps for starting or winch or windlass... turn them all on. Beneteau does this for good reason. Now, people will post that what they have is best....
Check out the second picture in post 8 at https://forums.sailboatowners.com/i...-red-electrical-switches.191463/#post-1456512. That's pretty much the ideal state in terms of flexibility and robustness. Converting to that from the default Beneteau configuration would probably require a bus bar, ACR, and some short lengths of cable.
