Marked the track
Gaute I too marked the track with a marker but I made the marks in the holes rather that the track itself. I figured there was nothing to wipe the ink off if it was in the hole. As far as the leech flutter is concerned you may just have to tighten the leech line a bit more. Just be careful not to over tighten it as it can cause a cup to form in the leech which will cause the sail to lose some efficiency/power. Why it only happens to you on the port side is a question with a number of answers. You may have some slight difference in how the sail is trimmed. You could also have some difference in how the mast is tuned. Shrouds on one side could be tensioned differently than the other allowing the mast to bend a bit more on one tack versus the other. And of course sometimes it's just the direction of the wind and your angle to it. Remember air has a directional flow to it and if you have a high pressure system over you you'll get clockwise direction winds, counterclockwise in a low. Depending on which you have the air will flow differently over the sails, creating the need to trim on one tack differently from the other. Every boat I've ever sailed reacted slightly different from one tack to another. It's also the reason you can sometimes point higher on one tack versus the other. Bottom line is to just make the necessary adjustments, check your boat speed for confirmation that it helped and remember what you did so you can redo it after the next set of tacks.Mike
