Frigoboat Refrigeration - Heat Exchanger Hi all,Can anyone help me. I have a frigoboat eutectic refrigeration system (Series 500 Plus). Today I had the fridge mechanic replace the compressor and re-gas the unit. After he left I noticed a small water leak from the heat exchange unit. The heat exchange looks like you can open it up by unbolting the 4 outer case bolts. What I am hoping for is I can replace the body of the unit without having to have the gas removed and dissconnecting the the copper pipe. E.G the coil of copper pipe just lift out from the case?Can anyone help.My run of luck with this boat is starting to get to me.*grrThanks in anticipation.Mike GibsonRaby Bay Australia
