Beneteau 423
38
Beneteau 423 Beverly, MA
Hi.
I have a 2004 423 that has a C70 Raymarine Chart Plotter with Integrated Radar. The GPS/Chart Plotter works great. I'm having a problem with the radar in that when it's turned on it pops the breaker after an random amount of time. I've following the lines looking for chaffing, loose ground, ect. and have turned up nothing. I'm just curious if anyone has encountered a similar problem and if so, what the solution was. Thanks.
Bryan
Jun 1, 2004
227
Beneteau 393 Newport
Remove the cover and check for a binding antenna. If it is binding for some reason, it will increase the current draw and blow the breaker.
Jim
larryw
Jun 9, 2004
395
Beneteau OC400 Long Beach, CA
Try running one size larger main power line to it. Dealer always install electronics with the smallest wire they can to save money, 'cause many times the ABYC specifies a size that will work over a given length, in a perfect world. Add the tiniest variant, and it pops a breaker.
DougM
Jul 24, 2005
2,242
Beneteau 323 Manistee, MI
Raymarine recommends a separate source of power for the radar antenna, Hopefully tou are not attempting to power it throughthe chartplotter circuitry. Check your chartplotter manual, it shows a recommended wiring method.
Beneteau 323 Annapolis MD
Put in a bigger breaker if the wire size will support it- and see if it still blows.
