Beneteau 423 toe rail
Beneteau 323 Toronto ON
Anybody knows what kind of wood is the toe rail made of on 2006 Beneteau 423?
I am looking to treat it. The cockpit floor and seats are teak and I treated them with Semco sealer, they look good. But the toe rail looks a bit differently, not typical teak grain.
It might be plastic made to look like teak. That’s what they used for the toe rail on our 2014 37. Not sure when they switched.
Here’s the best picture I have of the plastic tie rail -
Feb 21, 2013
4,638
Hunter 46 Point Richmond, CA
I am looking to treat it. The cockpit floor and seats are teak and I treated them with Semco sealer they look good. But the toe rail looks a bit differently, not typical teak grain.
If it is teak, then it just needs to be cleaned & sanded then sealed with Semco, if you want to use the same sealer. Below is a photo of a 2018 Tayana 48 with treated toe rail.
Thanks all, I will use Semco, I find it to be the most practical treatment for wood, not bad looking too.
Likes: sail sfbay
Feb 19, 2020
15
Beneteau Oceanis 38 Newport R I
I have a 2016 Beneteau 38 Oceanis. The toe rail is plastic not teak. check closely
