Beneteau 41 Acrylic Window Scratch Removal
36
Beneteau Sense 50 Waterford Harbour
I have a number of hairline scratches on my windows. Probably from the wrong abrasive cleaner and brush. I have used Novus 1-2-3 (#3 is for heavy scratches) with limited luck. I'm about to go to the 2000, 1200 grit sand paper then back to Novus.
Can anyone provide a good guide to doing this right? Equipment, cloth, process.
May 25, 2013
36
In addition to my original posted question, are the B41 windows acrylic or polycarbonate?
May 25, 2013
36
As I continue to search further on restoring acrylic, I found Micro-Surfaces. They manufacture a micro-mesh cushioned abrasive sandpaper. They have very thorough instructions and tips to restore acrylic back to original optical quality.
http://micro-surface.com/index.php?main_page=index&cPath=6_146. This link should take you to their marine page.
http://youtu.be/WnQDNS0nKH0 This YouTube link is a 15min detailed video of the restoration process.
I'm ordering the light damage repair kit and will let you know how it turns out.
Jul 12, 2012
73
Beneteau 41 Kemah
A pleasure to make your acquaintance. Ron Anderson, Compromise, Watergate. Looking forward to hearing the results. Missed you on the Harvest Moon. Only two 41s showed up.
