I have had a 36 CC for the past 13 years. When launched, the speed is far better than mid season, I realize that in the Chesapeake with water temps near 80 deg the marine growth can be quite somethjing, knowing than, I usually use a Dri-dive to clean the hull, but can't get to the keel. Also have the 27 hp and usually cruise at 2750 which will yield about 6.3 knots when launched, 5.7 to 5.9 at mid season (knot meter, not GPS) due to the growth on the keel. Given a head wind and 1 to 2 ft waves, speed will ofter drop to near 5.2. We do carry a RIB on davits, when towing we generally will lose also a knot in boat speed, regaining the lost speed when the RIB is carried. Can't say I have ever seen 7 knots under power, but have surfed down some seas at over 9 knots (again knot meter and not GPS0, although the latter has given readings of 10 + knots during that time). I suspect that your speed is a tad slow but not unreasonable based on my experience on the Chesapeake. One possible factor which might be relevant would be the calibration of your meter. Have you run a trial in flat water to verify the setting?
Regards,
Kevin
Esprit Irlandais 36 cc
