Ben361_owner
Hello. I have the following symptoms on my Beneteau Oceanis 361 rudder and need your help. During sailing the wheel rotates freely and is quite light, except of course of the usual whether helm. If I press the boat a lot and for a long time (only during a race), meaning heeling at 20 degrees or more the rudder due to the continues and excessive whether helm gradually becomes very stiff to turn but will take some time, a couple of hours probably always depending how much I have pressed it, to become light again (this is probably unusual). OK I understand that the boat has some limits and this symptom will occur if I pass these limits for a long time. But the question is why stiffness needs time to disappear?
Now the boat is out of the water and if I give the rudder a shake there is probably 3-4mm play from side to side.
What do you think? Is it a problem of rudder bearings that need replacement? Does it sound an urgent project for this winter?
I would like to hear your suggestions.
Thanks
Thanks
