Beneteau 331 Microwave
henryD
Jun 11, 2012
7
Beneteau 331 Jersey City
Has anyone installed a M/W on a 331 that did not originally have one? If so, how do you remove the bar over the storage area where the M/W goes? Also, is there another outlet for it somewhere around the drawers? The wiring diagram shows one but I can't seem to find it. Mine is a 2004 model.
Beneteau 343 Saint Helens, Oregon OR
I don't know how the 331 compares to the 343. I did not get the factory MW. Mw location was cabinet with door and shelf. I removed cabinet door and shelf and made two support pieces that fit under the mw feet with indents for the feet. I then ran screws into feet to hold it. Jammed everything in as high and back as far a possible. It leaves me a space about 4 inches high under that i store paperplates and napkins in. Wired in a short extension to the 120 outlet above the cabinetry.
I think the mw is the same model as used by Bene - 500 watt. I can run off the inverter.
