Beneteau 323 Battery Question
Jan 23, 2019
13
Beneteau 323 Kenosha
The Beneteau 323 has an Engine Battery and a House Battery. In the past, I have used the same two AGM batteries.
I was wondering if I should use an AGM Starting Battery for the engine and an AGM Deep Cycle Battery for the house battery?
I'm not sure if the Xantrex Battery Charger would handle both types?
Also, I'm not sure if the House Battery and Engine Battery are operating on separate circuits.
Have you used separate starter and house batteries, two starting or two deep cycle?
Let me know.
Thanks
For small diesels a deep cycle battery is fine for starting the engine, and having two of the same model can provide some redundancy and simplicity. It’s good to keep the same type of chemistry (both AGM) rather than mixing AGM with flooded or gel. Beneteau (and previous owners) has changed the way the battery circuits are wired over time so you may need to check your wiring to see when the batteries are isolated vs parallel.
Jan 7, 2011
5,877
Oday 322 East Chicago, IN
For a long time, I used 2 deep cycle marine batteries to run my house system and for starting the engine (I have a Yanmar 2GM20F. ). Each battery went to a separate post on the 1-2-both- off switch. I think Benes use a different switch arrangement, but it can work the same. I would use battery A one day, and Battery B on the next day. Worked Ok. No reason you can’t have a separate starting battery, but not really required.
Then I switched to 2) 6-volt golf cart batteries. these were wired in series to give me a 12-volt battery. I did not have any start battery…just used this 215ah 12-volt bank to do everything.
Last year, I added a 12-volt “starting” battery to my system. It was just connected to battery 2 on my switch, and I could just switch to battery 2 if the house bank was weak…. All of this was charged by an old Guest battery charger that had 2 outputs (10 amp &5 amp). I see no reason your current battery charger can’t be used to charge 2 batteries, both being Lead Acid (AGM is still lead/ acid chemistry).
This year, I decided to wire the start battery directly to the starter (with a cutoff switch), and separate it from the house bank. This was in anticipation of going to Lifepo4 batteries. My 2 golf cart batteries are 5 years old and on their last legs. I could probably day sail on them the rest of this year, but I am planning g a few weekend sails on the hook, and don’t think they will keep the fridge and lights on over a weekend. So I just bit the bullet and ordered 2) 100AH LIFEPO4 Batteries. I will wire these in parallel to give me a single 200 ah house bank.
With the addition of the LFP house bank, I did purchase a new battery charger just for the LFP battery bank. My old charger was not designed for the Lithium Chemistry, and I did not want to take a change of ruining my new battery bank. But this really driven by the addition of the LFP battery bank.
Greg
Jun 21, 2004
3,055
Beneteau 343 Slidell, LA
On my 2006 Ben, I have one AGM deep cycle starter battery (gp 31) & three (gp31) deep cycle batteries for the house bank. The starter & house banks are isolated. As @Davidasailor26 mentioned, there are different wiring configuration, even on the same model, so you will have to check it out yourself. A quick test is to turn on the negative black switch, turn off the red starter battery switch (#1), & turn on the red house battery switch (#2) and attempt to start the engine. If the engine starter doesn’t energize, the start & house banks are isolated. You should be fine, with regards to the Xantrex charger being suitable for charging both banks, just make sure that you have the switch on the charger set to AGM. Don’t know how you use your boat; however, seems that you may be under powered with only one house battery, especially if you use DC powered refrigeration. As my start / house banks are isolated, I have an inexpensive set of jumper cables on board in the rare event that I need to combine the two banks. Note that many have repurposed the black negative switch to enable the two banks to be combined in an emergency situation, if the starter battery becomes depleted. I am using AGM deep cycle Duracell (East Penn) AGM’s from Sam’s club & have had good results. With LiFePo4
batteries substantially decreasing in price, will consider converting in future with upgrading alternator & charger.
Likes: kloudie1
Jan 23, 2019
13
I'll try the quick test with turning on and off switch #1 and #2 to see if the start and house banks are isolated.
Thanks
7,605
Alden 50 Sarasota, Florida
Thanks
Even easier, just measure voltage at each. It’s virtually impossible they would read the same unless they are interconnected
Likes: JoeWhite
Jan 23, 2019
13
Kloudi 1 - I tried the quick test with the negative black switch on, with the red starter switch #1 off, and the red house battery switch #2 on.
The Yanmar engine started with the starter switch #1 off. I also turned off the house battery switch #2 and turned on the #1 switch and turned on the refrigerator and instruments. It doesn't look like the Engine and House batteries are isolated. See attached file from the Beneteau 323 manual.
Walt
Likes: sbliley
