Beneteau 12VDC Panel indicator lights
Jun 21, 2004
2,817
Beneteau 343 Slidell, LA
Anyone know the source & part number for OEM indicator lights for a DC panel of 2006 Oceanis vintage. I believe that they are incandescent. Emailed the
manufacturer but not reply. Plan to contact Ward @ Beneteau USA to see if he can help.
Jun 21, 2004
2,817
Was able to order exact replacement for the DC panel indicator light from Beneteau spare parts, SC.
The Beneteau part number & description follow:
Beneteau # 112495, LED light, RED, Ultra Panel Marine (UPM), $11.85 + shipping.
Your Beneteau dealer of choice has to initiate setting up an account with Beneteau to enable parts orders. The item(s) are shipped from Beneteau, SC.
2,817
Quick update on the DC panel indicator light.....typical boat project!
So I received the replacement light from Beneteau ($11.85 + 15.00 shipping). Attempted to replace the light & it didn't fit, so I lubricated it with liquid dish washing soap & used a towel to get a better grip on the bulb. The bulb cracked & separated from the two wires; $26.85 down the drain!! I noticed that Amazon listed a similar bulb (Blue Sea #8171) for $3.98 (free shipping); however, it required an 11/64" hole; likely the same as the one that I received from Beneteau. Ordered the bulb & drill bit from Amazon and received it two days later; installed it this afternoon and it looks like the others when illuminated! Will definitely hold on to that drill bit for future use!:banghead:
