ben 343 companion way water pooling
avago
Oct 17, 2012
5
beneteau 343 sydney
my ben 343 is taking in water, which is collecting in front of the engine pit under the companionway.It appears to be coming from a weep hole that drains into the companionway. Any advise on where it may be originating from?
Nov 8, 2010
11,386
Fresh or salt? Correlation with rain? if salt check cooling system while under pressure.
Toasts comments have merit also. Try turning off pressure water and see it it still happens.
You can also selectively turn off water at the manifold.
Mike B
Apr 15, 2007
1,013
Beneteau 43 Baltimore, MD
Like French Toast said check the swim platform shower, both the nozzle and mixer valve.
avago
Oct 17, 2012
5
beneteau 343 sydney
Located leak..sea cock in head outlet.. 1-2 drops every minute. Many thanx for advice.
avago
Oct 17, 2012
5
beneteau 343 sydney
leak resolved..sea cock in head. thankyou for advice
