HI all
I replaced my belts on a yanmar 2GMF.
After about 15 hours the over heat alarm sounded.
I checked the path and found the belt had some play.
I figured that I had not torqued the set nut enough.
Reset the raw water pump and off we went.
fast forward 15 hours the overheat alarm sounds and the
I check the belt and it has play in it.
Do belts stretch that much in 15 hours?
Or is there a setting for torque that I am missing on the set nut?
Your input will be great.
Mark
Dream Too
Mark
Dream Too
