Beeneteau 42 CC
Dec 28, 2015
2
Beneteau 42 CC Vancouver
Can the steering wheel be replaced with a folding wheel and if so do you need a wheel puller to remove the existing one. It does not come off by taking the nut off the centre post.
Jan 6, 2014
35
Oceanis 351 Helsinki
It should come off by removing the centre nut. Knock the wheel with hammer (easy), it should help.
KD3PC
1,069
boatless rainbow Callao, VA
center nut should come off easily..then use a no-bounce/dead blow hammer to tap the center hub. Else you may want to borrow or buy a puller. Folding wheel for that hub should be easy to source. We went with a smaller wheel instead of a folding one, on our B 36CC.
bshock
Jan 18, 2013
126
Beneteau 361 Sandusky Harbor Marina
One of my first upgrades on my b361 was a folding wheel. I didn't need a puller or anything. Once the nut was removed it came right off, and the folding wheel went right on.
Dec 28, 2015
2
Unfortunately not the same on the 42 CC. I took off the nut and washer and tied to tap the wheel to try and get it off but it does not budge. Had no problem with my previous Hunter 34. The wheel just slid off easily.
Sep 23, 2009
1,476
Do not tap the wheel but tap the shaft while pulling on the wheel center. If using a metal hammer put the nut on loosely to protect the threads. If the key is too tight you can grind it down. Should slide on and off easily.
