OK, I got it
Good picture, thanks for the clarification.Here's what I would do if it were my boat1. Depend on the integrity of the sealant YOU place behind the outside frame of the Beckson port. Slather LOTS of sealant on the vertical surface outside the window opening, press to fit.OR2. Step A -- spend lotsa time sealing the edge of your opening with whatever material you can find to suit. You could easily use gasket material of some sort, but with the edges I see you have, you could use Marine Tex and make the edges solid. Marine Tex or any other epoxy would dry in a day. You could also simply use silicone sealant on the edges, slather in and fair to a flat surface and let dry for a few days. Step B - just do 1 above.Your choice to do a one or two step. Your choice to deal with the integrity of the edges, although the Becksons when properly sealed from the outside, work very well.Your boat, your choice, it ain't the Beckson's.PS -- I agree with John, too, who just posted above this.
