More info
If the boom is out 30 degrees, trim issues related to twist shouldn't kill speed to the point of feeling like you aren't moving. What's your speed difference on close reach and beam reach in the same wind? What's the trim of your jib. Beam reach is funny because you are still powered with lift forces, not drag, but the noise and wind in your face dies down and makes things seem much calmer. I don't know your experience, but if you are very new, the difference between on the wind and beam reach can be dramatic with little difference in boat speed, just because of the apparent wind.Nope, just looked at your profile. I'm not telling you anything new. I suspect you meant the leeward side on the traveller and that I'm barking up the wrong mast entirely.
