F
Francis
I have a simple question.I was recently at lake Powell last week and noticed a couple of Mac26x beached, and other boats beached. I would of like to of done that but am conserned that if I go in to shallow my prop will hit ground and I would not be able to get back to the deep water to back out. I have a 9.9 motor that you have to hand raise.Do you need a motor that is electric that will raise up plus is the prop the same and can be angled up to avoid it from hitting? And if that is the way that it works, can a 9.9 honda be rigged like that, or do I have to buy a larger motor with the controls? I also fear scratching up the bottom if I beach the boat.I often wondered if dropping an anchor off the stern and then drift into shore would be the way to go. Then just pull on the anchor line until I get back out into deep water before I drop my motor down to start it up. I would should like some advise on this. I know it's kind of a dumb question, but I'd still like your advise.Thanks.
