A Acadian_53 . Oct 5, 2021 5 Bayfield 29 Caraquet Oct 5, 2021 #1 Hi sailors Anybody knows what kind & size of cutlass bearing on a Bayfield 29 and where to get them? Best regards
sail sfbay . Feb 21, 2013 4,638 Hunter 46 Point Richmond, CA Oct 5, 2021 #2 Welcome to the forum!! Suggest measuring your shaft diameter and then consult with Duramax Marine Bearings, Heat Exchangers, Seals & Impact Systems Buy cutlass (or cutless if a Johnson-Duramax) bearing from an on-line or local chandlery like this site SailboatOwners.com search. You might these articles helpful: Replacing A Cutlass Bearing (Sleeve Bearing) - Marine How To and Replacing a Cutlass Bearing on a Boat - Marine Engineering Services
A Acadian_53 . Oct 5, 2021 5 Bayfield 29 Caraquet Oct 6, 2021 #3 Thanks for the info Hunter 46, much appreciated.
H hsailor . Aug 24, 2020 1 Bayfield 25 Ottawa Nov 18, 2021 #4 I had posted this earlier: (Log In) - Duramax Bale 1x1 1/2x4. The inside diameter is 1", outside diameter is 1 1/2", and length is 4".
