I've installed chargers on both 6 HP Tohatsu,(Nissan, Mercury), and our current outboard, a 5 HP Honda. The Tohatsu was cheaper, but only uses a single coil. The Honda is more expensive because it's first off, it's a Honda, and the Honda requires a new flywheel,(included in the kit). They use two coils and I've found the Honda delivers higher voltage at a much lower RPM, probably because of the dual coils? I don't know. The Honda amperage rating is about half of of the Tohatsu. Either chargers are fairly easy to install in less that an hour, and you would have to work really hard to hook the wires up wrong. But caution, "IF" you have any problems, Honda will not talk with you, and my dealer told me to go pound sand when the new kit came with a bad rectifier. My experience has been that they will keep up with our normal electrical load of running the autopilot, GPS, and VHF radio, and still have some left over to trickle charge the battery. But the GPS and VHF are real low consummers, and the autopilot isn't really bad either. I've switched to LED's for my running lights, and being that my boat is less than 23', and I don't anchor for the night in a channel, I've removed the factory anchor light.
Don
