Last season I installed 4 new Trojan T105 6v/225amp batteries in the configuration shown in the attachment. At the end of the season the hydrometer reading on the cell at the positive end of the No.1 battery was below all other cells. It's been suggested that voltage drop is the issue and I should move the Neg. bus-bar to 3ft from bank B and this would balance the voltage drop.
Can anyone tell me if 1. Does moving the neg. terminal make sense and 2. If I simply lengthen the positive and negative cables on bank A to both 6ft to match the cables on bank B would this solve the imbalance or is something else at work.
